跳转到主内容
加入维修社区 - 创建账户
2025 年初发布的 Beelink Mini S13 (N150) 迷你电脑的维修指南、拆解和故障排除信息。
How to remove the motherboard
I can remove the cover on the bottom and remove the 4 screws of the motherboard.
So far I was unable to remove the motherboard from the case, because it seems the HDMI and USB connectors are stuck in the holes of the case.
Do I need to bend something or is there any additional screw etc. still attached, which needs to be removed?
I want to remove the motherboard, because the CPU fan is very loud and I want to make sure the fan or heatsink is not dirty or thermal paste needs to be exchanged.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Hi, you can refer to this MINI S12 teardown tutorial: https://url.bee-link.cn/F5R9
If you need any further assistance, please feel free to contact our support team at support-pc@bee-link.com. We'd love to help!
这个答案有帮助吗?
得分 2
1条评论:
Thanks for the info, I guess that helped.
It would be helpful, if you put that video on YouTube or any other video platform, so users don’t have to download a 1 GB zip file just to watch a 3min video.
完成的
添加一条评论
Don’t bend anything. On most laptops/mini PCs, the motherboard won’t lift straight up because the HDMI/USB ports are keyed tightly into the rear I/O cutouts. After removing the visible screws, double-check for hidden screws (often under stickers, rubber feet, or near the fan). Also disconnect all ribbon cables (fan, power, speaker, Wi-Fi antennas) before lifting. To remove it, gently slide the motherboard sideways (toward the front) to free the ports, then lift it out at a slight angle. For the loud fan, clean dust with compressed air and replace thermal paste if it’s dry or cracked.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Sim 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 21
过去 30 天: 98
总计 672
