跳转到主内容
加入维修社区 - 创建账户
HP Compaq 8200 Elite 是一款小型工作站级台式电脑,面向高端办公和设计工作。它的设计相当易于维修,重点在于让技术人员能够快速更换驱动器和板卡。
Pc is on, no display then fans go loud. No sound
When my desktop is switched on it starts as normal but yet no display. Everything seems fine and working, yet . After about 3 minutes of running and no display the fans go really load. I've tried replacing the RAM but seems not to be the cause of the problem.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @tarhbeteckayuk
Try a full power refresh in case the BIOS has become corrupted and is preventing a normal start i.e the PC is not passing POST (Power On Self Test)
Here’s the procedure:
a). Disconnect the power from the PC
b). Open the case remove the coin cell RTC battery from the motherboard. Here’s the hardware maintenance manual that will help
When the coin cell battery is removed from the motherboard, use a DMM (voltmeter function) to measure the battery’s voltage. If it is <2.5V DC or if the battery is >4-5 years old, replace it. It's a CR2032 Lithium coin cell battery that is available most everywhere.
c). Press and hold the Power on button for 30 seconds and then release. This will restore the BIOS back to the factory default settings.
d). Reinsert the coin cell battery (or replacement battery) on the motherboard (+ve on top as marked on the battery)
e). Reassemble the desktop, reconnect the power to the PC and check if it turns on OK,
If it does there may be a message on the screen about the date and time being incorrect. This is normal as the BIOS has been reset. Once the date and time have been corrected, the message won’t appear the next time that the PC is started.
这个答案有帮助吗?
得分 2
1条评论:
Thank you very much, I appreciate it
完成的
添加一条评论
添加你的答案
TARH BETECK AYUK 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 32
总计 190
