跳转到主内容
加入维修社区 - 创建账户
A1708/EMC 3164—于2017年6月上市,这台入门级MacBook Pro保留了它的传统功能键(相对于OLED触控条)。
What if I broke the clip on the sister ribbon connector
as I was replacing the battery I accidentally pulled the sister ribbon off on both ends. As I was trying to reconnect it I think I broke the cable latch on the big side. It isn't detecting the battery, it will not hold a charge and will not work if unplugged from the wall and the fan stay on the whole time also the key board isn't working . I took it to a repair shop and they said they reconnected it with the old ribbon and told me that the new ribbon that I purchased from Ifixit wasn't the correct ribbon. She told me that I would have to keep it plugged if I want to use it and that I would need to use an external key board!! Well this is the reason I replaced the battery as it wasn't holding a charge unless being plugged in. Maybe I messed it up - wondering if I just need to ditch the project and buy a new one...not really in my budget but I need a working lap top
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
@kristinam66215 let's see what the damage looks like. Post a couple of well focused pictures of that with your question so we can see what you see. 在已经存在的问题里加入图片
完成的
添加一条评论
1个答案
From your other note it sounds like the Zero Insertion Force (ZIF) cable connectors latch was lost. Review the steps 11& 12 in this guide 2017年款带功能键 的13寸 MacBook Pro 电池更换to verify that they are both present. The do need to be present and set as they compress the cable to create the needed connection.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Kristina M 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 3
总计 24
