跳转到主内容
加入维修社区 - 创建账户
Wii U 是任天堂推出的一款游戏主机,配有一台名为 GamePad 的手持设备,允许用户通过 GamePad 游玩游戏。该主机的维修非常简单,因为设备采用了高度模块化的设计。
Wii U Disc Drive makes awful sounds (inserting/spinning)
So recently my cat pushed my Wii U from my desk and fell pretty hard.
While the disc drive still read and writes, inserts and ejects perfectly. The sounds it makes when I insert a disc is broken. When it spins (reads) it makes scratching sounds but it doesn't scratch the disc at all.
I do have some audio if one is interrested.
I do found some ebay disc drives but not sure how I would transfer the logic board.
Would it still be possible to repair the one I have?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi!
Yep, some moving parts inside the disc drive are touching each other making that awfull scratching sound…
It’s the metal plate where the disc spindle is on it.
Unfortunately, it’s very difficult to find those parts and not easy to repair. So I advise to replace the disk drive completely.
You can find the guide here: Nintendo Wii U DVD 驱动器更换
Transfering the old PCB (drive board) from your broken drive to the new drive is required, otherwise it won’t read games.
Glady it’s not difficult to replace it (you need to open up the drive and get the board out).
If you really need a guide, please let me know!
这个答案有帮助吗?
得分 2
4条评论:
Hi, sorry for the late reply.
I changed the PCB but now it doesn't want to boot anymore.
When I want to turn it on the LED goes blue and then turns red and it flickers slowly.
完成的
Hi! No problem at all!
Sound like a different issue to me. Are you sure that the front faceplate is correctly installed? Guide > Nintendo Wii U 前盖板更换
If you are 100% sure, then I would test with a new power supply and see what happens...
完成的
Hey,
Thanks again for all the help you gave me.
I took it apart again (not the disc drive) and reinserted all the ribbon cables and now it just boots up. The best thing, the new disc drive doesn't make weird noises or scratching noises.
I might have not fully inserted a ribbon cable.
I really appriciated the help.
I thought I was doomed or had to pay 200€ to get it fixed.
Thank you again
完成的
Hi!
Glad that you got it solved now :)! It did sound like that yes. Gladly that was it.
Have a nice day and take care!
完成的
添加一条评论
添加你的答案
Thibeau De Smet 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 14
过去 30 天: 39
总计 313
