跳转到主内容
Repair guides and support for riding, or ride-on, mowers, also known as lawn tractors, of all types used in tending large tracts of land.
851 个问题 查看全部
问题已关闭
I need help with fixing the head gasket valve
So i've been working on a quality farm and country head gasket and in the big piston inside theres a little gap at its edges. Is that bad or should i replace it
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
3条评论
now you need to tell us who built the engine for your mower. It is definitely an AYP and if it is the same mower as from your other question, we know its a 16.5 HP. Is it B&S or Kohler or anybody else?
完成的
B&S it is the other one
完成的
when you turned it on a lot of smoke blew out and it would turn off, so we're changing the head gasket valve. And hopefully that's all we have to do
完成的
添加一条评论
1个答案
已选择的解决方案
It is normal to have some "gap" at the top of the piston. The rings make up the difference in size and seal between the piston and the cylinder wall. Here is an example picture:
http://www.rlengines.com/tech/rings.jpg
What was the original problem that lead you to tearing the engine apart?
BILL
这个答案有帮助吗?
得分 2
1条评论:
Bill, click on Juan icon to see his other questions on this mower. If nothing else, he's persistent.
完成的
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 374
