跳转到主内容
加入维修社区 - 创建账户
问题已关闭
LG shows no signal
shows no signal even after following instructions other tv's are connected to wifi
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
4条评论:
What is the make and model number of the TV? Does the TV screen turn on at all?
由完成的
Yes it turns on displays a LG with a 3d cube around it under that is says no signal
由完成的
@stevelafferty
Have you tried using different signal sources e.g. HDMI, RF, AV or cables?
What have you tried?
由完成的
My tv turns on but doesnt shows main screen directly opens a source
由完成的
添加一条评论
1个答案
Your LG TV displaying "No Signal" typically means the issue is with the current input source (like HDMI from a cable box, gaming console, streaming device, or antenna), not the TV's Wi-Fi connection. Since you mentioned other TVs are connected to Wi-Fi (and presumably working for streaming), and you've already tried some instructions, this points to a problem with the external signal/input rather than internet/apps.
Try a soft reset on the TV: Go to Settings > General > Reset to Initial Settings (this won't delete apps if signed in, but back up if needed).
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 33
过去 30 天: 94
总计 847
