跳转到主内容
加入维修社区 - 创建账户
大众途观是一款紧凑型跨界 SUV,它拥有时尚的设计、舒适的驾乘体验以及充足的载货空间。
Why is my engine signal on?
My car's engine signal is showing on the dashboard
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
You should check this with an OBD scanner, as 2018-2024 VW Tiguans have had significant engine issues. There’s a class action lawsuit against VW in the USA and Canada over this. If you’re noticing low oil levels or oil leaks, the most common culprit is a faulty PCV valve, so it’s worth getting it inspected.
这个答案有帮助吗?
得分 0
添加一条评论
As @kashifkhan71851 stated, the car's engine computer is telling you that it's seeing a fault related to the engine. It could be minor or it could be major; there's no way to tell without reading the Diagnostic Trouble Code(s) stored in the computer's memory. An OBD-II scanner is required to read those; such scanners can be obtained for anywhere from under $5 USD to several thousand dollars. Here in the US, most auto parts stores will scan your car for free and give you a list of the code or codes that are present.
Most scanners have the capability to turn off the "check engine", or Malfunction Indicator Light, but of course if the problem hasn't been fixed, it'll just come back on again, so you have to actually fix whatever is wrong before you get the engine codes cleared.
Assuming you get a list of the code or codes, come on back and add that information to your question, along with the year, engine size, transmission type and any submodel information about your car that's relevant. Once we have that, we should be able to help you figure out what's wrong and how to fix it.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Nana Yaw Nenyinaaye 将永远感激不已
浏览统计数据:
过去 24 小时: 5
过去 7 天: 12
过去 30 天: 27
总计 100
