跳转到主内容
问题已关闭
My model number isn't listed.. which guide for 2.4GHz MB133LL A
Hi, you don't list guides for Early/Late 2008 MacBook Pro Core 2 Duo 2.4Ghz 200mb HD, MB133LL/A as the Model number. Which of your corresponding model numbers is correct? I've searched all over -
Need to replace a hard drive. Will an SSD Sata II work?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hello,
Your device is actually listed under the MacBook Pro section of repair. It is the A1260 model and all the repair guides for it are right here:
MacBook Pro 15" Core 2 Duo Models A1226 & A1260
What kind of SATA II drive were you looking into?
Hope this helps.
这个答案有帮助吗?
得分 1
3条评论:
Intel 330 series 180gb.
完成的
Thanks, that helps I could not find a model number other than what I listed anywhere.
完成的
Yes, the Intel 330 series will work in your MacBook Pro. I'm using a 330 right now. (If the answer is helpful you can mark it as answered)
完成的
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 2
总计 753
