跳转到主内容
The TH (turbo-hydramatic) 700R4 was developed for use after 1982 in GMC and Chevrolet cars and trucks.
37 个问题 查看全部
Is the 700R4 interchangeable with the Turbo 350?
Probably I will get nailed for this one, but here goes.
I have a 1986 Chevy K20 Pickup. It originally came with a Turbo-Hydramatic 350 transmission. It has a 700R4 installed now, which is shot. Will I be able to re-install a T350 with no other wiring or tubing modifications? Should I just be safe and find another 700r4 and throw it in?
Off computer topic I know, but hey do I care? There is a big knowledge base out there.
Regards,
Frank
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 5
9条评论
It's definitely a hardware problem ;-)
完成的
Got a 77 Malibu with build 305 an 350 turbo can I change trans over a a 700r ?? Or a 400turbo??
完成的
My advice is avoid a transmission that utilizes a Throttle Valve Cable. The plastic buckle on the end breaks, Doesn't matter what gear you're in, how fast you're going, or how far you drive with the cable not attached. You burn clutch material and it wears the gear down no matter what, more than likely resulting in a complete failure of the transmission. I've been through 2 in my 89 GMC c1500 305 slx, can I put a turbo 350 or 400 in my truck without doing anything other than the swap itself and the fluid change?
完成的
I put a 350 turbo in place of a 700 with the 9 inch tailshaft.i put the 700 tailshaft on to use the electric Speedo and the shaft sticks out of the back several inches any solutions?
完成的
Stick with what u have its supposed to be a bettet tanny
完成的
显示更多的4条评论
添加一条评论
10个答案
已选择的解决方案
This URL seems to answer your question. Good luck. Ralph
http://www.hotrodders.com/forum/can-i-pu...
这个答案有帮助吗?
得分 5
5条评论:
Read all the way down to get the speedometer info. Ralph
完成的
nice research +
完成的
Yeah, great info, thanks. My speedo is about 5 mph off since it must be the old style. So, whichever tranny I find cheapest and quickest will make it in there. Also, it's for sale :) https://accounts.craigslist.org/post/shw...
完成的
Would you like to sell the 700R4 I need one for a 92 Chevy Blazer it takes 700R4 4x4 posi Overdrive
完成的
Ya I got 2 of them as we speak. 700r4
完成的
添加一条评论
最有帮助的答案
350 hydromatics come in 3 tailshaft lenths (sic) 6 inch 9 and 12 they have the same output spline flexplate bolt pattern and engine mounting pattern to swap out a 700 r4 you need a 9 inch you will have to move the transmission support forward several inches .this causes a little alinement issue with the shift shaft in some applicatinos but it will work other than having either not enough positions or too many on the shift quadrant , and you better hope that you are swapping out an early 700 with a speedo cable as some later units(i think) had a speed sensor that means finding a new tailshaft cone and gears to drive the speedo cable there is a cable operated shift control on both transmissions and a vacuume operated pressure control on the 350 that warrants some understanding .also late 350s had a locking torque converter(adds an electrical ciruit) in an effort to improve fuel economy (but they also cut the weight out of some of the internal rotating elements at the same to reduce weight)some would say and reliability i'd call it an easy swap for any back yard mechanic certainly much easier than what you need to know to repair cars of only one decade later
这个答案有帮助吗?
得分 6
2条评论:
Good information thanks for sharing.
完成的
Ya the concern I have is will the drive shaft have to be changed too?
完成的
添加一条评论
I have a 88 Tbi 5.7 pickup that I backdated to th350 from 700r electric speedo I just wanted to state that the tail shaft housings will interchange and all you have to do is nab the speedo gear off of the 700r I did so with a lack of tools so I used a 2x4 and a hammer but needless to say it worked and that's the only snag I ran into for the back date except the crossmember which I had to notch and drill a couple holes in the frame..easy peasy I pull heavy loads and will never own another 700r again...oh one more thing..the vacuum...tee off of the map sensor from the manifold port on the back side of the Tbi and you will be fine be sure to use a steel line.. also I spliced the kick down cable with the TV cable so it would work with my brackets..cheap but effective... the 700r TV cable housing will not fit the 350 turbo all you need is a cable stop from any hardware store and switch out the ends at the motor side bracket that's all... took me two days to figure all this out as it was my first real mod... but it's not really all that hard and I would do it again in a heartbeat
这个答案有帮助吗?
得分 1
添加一条评论
I got a 81 chevy.4×4 what got do make the 700r work
这个答案有帮助吗?
得分 1
添加一条评论
Will the tail of a 700r4 from a car ,will it interchange with a 700r4 4x4
这个答案有帮助吗?
得分 1
添加一条评论
you will need to get a different tail shaft, the th350 is shorter, and to be honest, you want to the 700r4, get it rebuilt if you have to, the difference in fuel economy will pay for the cost of the transmission in time
这个答案有帮助吗?
得分 0
添加一条评论
i got a 57 chevy with a 4 speed now 0n a 350 motor & want to put a 700r4 in it. what will that take
这个答案有帮助吗?
得分 0
添加一条评论
i have a t700 changing to a t 400 what do i do with the 4 pin wire connector from the 700?
这个答案有帮助吗?
得分 0
添加一条评论
I have a 1969 powerglide tranny in a impala. I want to go to a t350 tranny its an older one they look about the same size will this swap go smoothly?
这个答案有帮助吗?
得分 0
添加一条评论
Man, get a kitted rebuilt performance tranny like this one :
https://www.ebay.com/itm/Dominator-700R4...
And get a convertor that is the right size to shift right at the torque peak of your engine (you might have to dyno to find this out)
Feed it with good, synthetic fluid, and it will take care of you for many years. I have found Redline, Nulon, Lucas etc to be the most reliable I've used. Good luck with it :)
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
040304 将永远感激不已
浏览统计数据:
过去 24 小时: 10
过去 7 天: 48
过去 30 天: 154
总计 122,864
