跳转到主内容
加入维修社区 - 创建账户
Apple 在 2020 年十月更新了 iPad Air 平板电脑,其采用 A14 Boinic 处理器,10.9英寸屏幕,全新外观设计,以及内置在按键中的触控ID。
Is there a Digitizer replacement for this model?
I am looking to find the correct digitizer part for ipad air (4th generation) wifi. A2316. I see the listing only for ipad air generically. iPad Air Screen Digitizer
Don't see one specific to 4th gen model. Are these parts compatible ? Thanks.
Replace a front panel assembly compatible with iPad Air. Assembly includes the glass touch panel (digitizer), blank home button, camera bezel, and adhesive.图片
产品
$29.99
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
The older models had a separate digitizer which was part of the cover glass as you noted from the original iPad, the newer iPad Air models use an integrated cover glass/digitizer/LCD screen assembly iPad Air 4/5 Screen and here's the guide to put it in iPad Air 4 屏幕更换 you'll also need the adhesive strips to mount it properly.
Replace a scratched or cracked front glass digitizer panel or a malfunctioning display on your iPad Air 4 or iPad Air 5.图片
产品
iPad Air 4/5 Screen
$189.99
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Arun Natarajan 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 14
过去 30 天: 43
总计 198
