跳转到主内容
加入维修社区 - 创建账户
13 英寸 MacBook Pro 于 2020 年 11 月发布,配备 Apple 基于 Arm 的 M1 SoC,具有 8 核 CPU 和 8 核 GPU。(型号 A2338 / EMC 3578,带有两个 Thunderbolt 3 端口)
MacBook Battery Connector Socket/Bracket Broken
hey guys, after i was trying to plug the ribbon battery flex cable back in, i accidentally broke off the bracket and now i don’t know what to do, i want to know if i can still use the mac without this part or like any solutions to fix it. please help, thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Ummm... you probably need that part. But only probably. I have no idea where that connector leads (but did you say it lead to the battery?), but knowing Apple's design standards, it probably wouldn't be there if it didn't do something that the computer needs to function. If you really wanted to find out, you could try plugging all the connectors back in and turning the computer on and testing all the functions to find out what it does, if anything. ...Just be careful if you try this. Don't short anything out!
完成的
添加一条评论
1个答案
已选择的解决方案
Sadly, that's the one cable you will have a very hard time finding as it's part of the logic board. Someone who repairs MacBook logic boards maybe able to transfer from a junker a replacement cable. The source I had found last year has disappeared when I needed one.
这个答案有帮助吗?
得分 1
3条评论:
I found this on aliexpress, can i just use this?
https://www.aliexpress.com/item/10050093...
完成的
@omar92016 - Good find! Yes that what's needed. You'll need a hot air rework station to re-solder it on. It's not easy as you need a fair amount of heat and some pressure after you tin the pads on both sides just enough not to short across.
完成的
Alright, thanks man
完成的
添加一条评论
添加你的答案
Omar 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 27
总计 237
