跳转到主内容
加入维修社区 - 创建账户
索尼 PlayStation 5 DualSense 手柄(第一代)的维修指南、拆解信息和故障排除信息,它是 DualShock 系列的继任者。可通过产品型号 CFI-ZCT1W 和主板型号 BDM-010 进行识别。
RT on Dualsense not working following joystick replacement
I've just replaced the joysticks and the right trigger just is not working at all. I've replaced the ribbon cable with another one from another bdm 010 controller but still not working sadly.
Grateful for any advice on how to check for a short or anything. This is my 2nd joystick replacement (first time on bdm010) I've got a multi meter
I am still buying replacement ribbon cablss from AliExpress just in case.
I have tried also:
switching the trigger modules and cleaning the membrane
cleaning the whole board with 99% isopropyl
hard resetting the controller
reddit post here on it
https://www.reddit.com/r/consolerepair/c...
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Hi!
How are the traces on the motherboard?
Can you show us some pictures regarding the motherboard and solder work?
Thanks!
由完成的
I can't seem to upload photos here but the photos of the the board are on Reddit here
由完成的
添加一条评论
1个答案
最有帮助的答案
Hi!
Reading the reddit post you did tried a lot of things already!
It could be the connector regarding where the ribbon cable goes in to.
Could also be that the board had too much heat causing something to die on the board.
If the connector is still fine and you already replaced that one, you might want to replace the board… it won’t be easy to find out what is broken there :(.
这个答案有帮助吗?
得分 1
2条评论:
Do you think it's worth me applying heat with a heat gun around the area where the connector is to try and "reflow" any broken/cracked solder joints? I'll kapton the whole board aside from the connector
由完成的
You can try to reflow the board and that part. I doubt it if this will work, but you can try and see what happens. Just make sure that the board is lying down stable and that it’s completely cooled down before you take it.
由完成的
添加一条评论
添加你的答案
toge 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 20
总计 225
