跳转到主内容
加入维修社区 - 创建账户
Google Pixel 7a 是 Pixel 7 系列中的经济型机型。Pixel 7a 于 2023 年 5 月发布,在 Pixel 6a 的基础上增加了面容解锁、8 GB 运行内存、大幅升级的摄像头和无线充电功能。
Pixel 7A replacement Battery tab appears to be in the wrong spot
While attempting to install my new pixel 7A battery I noticed the battery would not fit due to the tab being under the battery rather than over it when inserting it into the battery slot. Comparing the old (left) and new (right) batteries the new one appears to have the tab orientation flipped and so is not the same fit/function as the old one. Would appreciate if someone could sanity check if this appears to be a manufacturing defect as it seems like the new battery is not installable in the phone. The model # for both batteries matches as GP5JE.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
The Ifixit bot told me it was safe to bend the battery tab 180 degrees to match the correct orientation which seems to allow it to fit. Congrats on a helpful LLM bot.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Orlin V 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 14
总计 144
