跳转到主内容
13" aluminum unibody, 2.0 or 2.4 GHz Core 2 Duo processor.
574 个问题 查看全部
Can you interchange LCD lid/back between MacBook A1278 and A1286 Pro?
I've got a late 2008 A1278 macbook 13" which needs a new back cover/lid - can't find many macbook 13" lids, but plenty of Macbook Pro lids. Are they interchangeable ?
As far as I'm aware Apple just added "macbook pro" to the glass, correct ?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
3个答案
已选择的解决方案
Hi, a1278 is 13" a1286 is 15"
You probably have a1278 2008 model before they made them MacBook Pro. Good news is that they are interchangeable but the sleep magnet for the MacBook pros is on the right side whereas the MacBooks is on the left side. If you swap it over then it'll be good.
这个答案有帮助吗?
得分 1
添加一条评论
I do not believe so. I know they are both aluminum however, there will most likely be different connected on the back case for the lcd/led screen.
这个答案有帮助吗?
得分 0
添加一条评论
It looks like it is possible:
MacBook Pro 13" screen in MacBook non-pro Unibody
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Tom 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,650
