Can't open battery compartment
I haven't used my Sony dsc-w5 for several years. I am now unable to open the battery comparment. I suspect the battery has leaked and corroded the latch from the inside. How can I open the latch without damaging it?
charles, you could try and soak the corner with the battery door in a backing powder solution, and/or use a sprayer to try and spray some around the corners. Also, a toothbrush scrubbing might get it loosened. If you soak it, just place that particular corner in a solution, not the whole camera. The only other way is to disassemble the camera, the attached images may help you with that task. Hope this helps, good luck.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 1,922
