跳转到主内容
加入维修社区 - 创建账户
A1708/EMC 3164—在2017年6月上市,这台入门级MacBook Pro保留了它的实体功能键(相对于OLED Touch Bar)。
Is there enclosure to convert A1708 MacBook Pro's SSD to external HD?
I have an A1708 13.3" MacBook Pro. It is completely dead. I would like to take out its 256 GB SSD, put it in enclosure, recover my data and then use it as an external drive. What do I need? Is there an enclosure that will work with this that someone can recommend? Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
This question was migrated from https://meta.ifixit.com/Answers.
完成的
添加一条评论
1个答案
Sadly this model uses a custom SSD which is not standard or even consistent with Apples other custom SSD's. I'm surprised no one made a case for it so people could at least recover their data. A had a sizable customer who had a bunch of these for their staff. I managed to snag one just so I could recover files when the needed to swap out systems.
While I know that's not what you want to hear it's the only way I know of that works. See if you can find someone with the same model that is at least willing to slide your drive in so you can recover your stuff. Otherwise try to find a used one.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
dodurgali 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 18
总计 190
