跳转到主内容
加入维修社区 - 创建账户
From 1992 to 1996, chief engineer Kosaku oversaw development of the XV20 Lexus variant alongside the XV20 Toyota Camry programme under project code 416T.
What could it be when I changed the knock sensor and it starts smoking
I just changed my knock sensor and my car has misfire 1,3,5 and it smokes white aloe
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
White smoke + misfires on cylinders 1–3–5 after replacing the knock sensor on a 1996–2001 Lexus ES strongly indicates a problem with the intake manifold reinstallation—usually a leaking lower intake gasket, coolant leak into the intake, vacuum leak, or a damaged knock sensor harness. Recheck all gaskets, hoses, and connections under the intake. These issues are very common after a knock sensor job on the 1MZ-FE engine.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Manuel Arellano 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 6
总计 60
