跳转到主内容
Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1203 个问题 查看全部
Why my MacBook can not sleep?
When i close the lid, after 2 seconds the MacBook shuts down itself. Then when i open the lid, nothing happens. So i push the power button and i got a grey screen, then black screen, then the starting sound and finally a normal (??) boot. What can be?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
最有帮助的答案
When the battery is dead and the Book is put to sleep and the lid closed it will shut down. Go to Coconut battery and download and run the program. http://www.coconut-flavour.com/coconutba...
Tell us the battery status.
这个答案有帮助吗?
得分 1
6条评论:
Ok here we go:
Current Battery Charge: 1810 mAh
Maximum Battery Charge: 4929 mAh
36%
_
Current Battery Capacity: 4929 mAh
Original Battery Capacity: 5020 mAh
98%
Add Info:
Loadcycles: 539
Age of my Mac: 17 Months
Charger connected: No
Battery is charging: No
But remember, i got this problem with or without the power adapter.
Thanks for your patience :)
完成的
It's having a little problem finding the system folder. Insert the System Installation disk and start up holding down the "C" key. On the third screen a pull down menu will appear. Go to Utilities - Disk Utilities and verify the disk then run the disk repair.
完成的
Still got the same problem :(
This mac came originally with 10.5.2, and now im running the 10.6.2, should I downgrade the system and upgrade again?
完成的
Or a logic board issue probably?
完成的
I have found almost nothing on this issue. http://forums.macosxhints.com/showthread...
The one fix I did see that worked was a clean install of the system. It's worth a try.
完成的
显示更多的1条评论
添加一条评论
I would try resetting the PRAM, and then SMC before moving on to hardware issues ...
check this out for PRAM ... http://support.apple.com/kb/HT1379
check this out for SMC ... http://support.apple.com/kb/HT3964
Let's see how that works to start ...
这个答案有帮助吗?
得分 0
1条评论:
Still got the same problem :( Thanks a lot, anyway :)
完成的
添加一条评论
添加你的答案
Eduardo Xavier Manfredini 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,131
