第四代iPhone。维修过程直观易懂,但前置玻璃和LCD面板无法分开,只能作为同一零件更换。GSM版本, 8, 16, or 32 GB 容量 / 型号 A1332 / 黑色或白色
3260 个问题 查看全部
No voice and mic
All is working
Bat I cannot hear or speak on the phone.
When connect to Skype its working fine.
The mic and the ear speaker and the bottom speaker all work.
The water sensor on the board ar white .
Bat the sensor on the charging port is red.
What can be the reason for that ?
已回答! View the answer 我也有这个问题
这是一个好问题吗?
按维修分数 2
添加一条评论
所有超过US$100.00或包含 Pro Tech工具包的订单免费送货!
浏览我们的商店
5个回答
已选择的解决方案
Thank you very much for your time and thought
The problem was detected and corrected
its the Audio Chip on the board
Thanks again
You are great
这个答案有帮助吗?
按维修分数 0
添加一条评论
Check your headphone jack for debris, that might it sounds like it thinks u hv headphones plugged in.
这个答案有帮助吗?
按维修分数 0
评论:
so way is it working fine with skype.
if it was thinks i hv headphones plugged in.it was afecting in all aps.
what do u think???
添加一条评论
First obvious port of call is to replace the dock connector - however you've verified that from a hardware point the microphone works so I don't think this is your problem.
It sounds like the audio decoder. This is a fairly common problem with the 4 and 4S. Apples policy is to swap the phone out for a replacement but that's useless for phones over 12 months old.
If your iPhone is under 12 months old take it straight to your nearest apple store.
Symptoms are exactly as you've described. Sometimes the problem is intermittent whereby it will work for sometimes days without trouble but then will randomly mute for no apparent reason. It will then sometimes work from time to time but eventually getting worse and worse to the point that each and every call is the same.
Without some serious soldering skills your best off looking for someone to do it for you. I'm not aloud to advertise services on here but if you message me I can help. If not you please look for an experienced, reputable iPhone repair company - its not a simple repair.
这个答案有帮助吗?
按维修分数 0
添加一条评论
Hello I have the same problem , can you please tell me how you fixed it? thanks
这个答案有帮助吗?
按维修分数 0
评论:
The problem was on the motherboard audio chip (iPhone 4)
Common occurrence after a fall
It is necessary to warm him back to the place
Required to work with laboratory
Do not try at home if you dont Have experience
Follow the link to see the location of the chip
http://www.edibleapple.com/2011/05/19/ip...
must be cautious
good luck tamir
添加一条评论
same problem after fall down.
after a lot of search on net probably the solution is replace Audio Chip....but its so strange after fall down have to change this part no?
when i call i listen my voice come back to speaker and people can't listen to me.
there is a possibility that it was other noise mic reducer its faulty?
thx
hey guy!! just clean ACCURATE (the audio chip) and MY Iphone is become like new! thanks forum! :)
这个答案有帮助吗?
按维修分数 0
添加一条评论
添加你的答案
tamir 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 1
过去的30天: 8
总计 8,285
