跳转到主内容
加入维修社区 - 创建账户
13 英寸 MacBook Pro 于 2020 年 11 月发布,配备 Apple 基于 Arm 的 M1 SoC,具有 8 核 CPU 和 8 核 GPU。(型号 A2338 / EMC 3578,带有两个 Thunderbolt 3 端口)
Is my laptop done for?
Would you get this repaired or opt for a (new to me) refurbished laptop? I dropped my laptop one time recently and the one corner dented in pretty bad and the screen has some cracks. The display connection has been ruined and I just get a black screen with a little light on the cracks. What would you do?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
You decide: parts available here, click "parts" at the top of the page or just browse from the link below:
Replacement Screen alone is $500...
Now, that might be all you MUST replace, but that can only be determined by opening it up to find out what else is damaged.... And your personal preferences... The degree of damage to the case is unclear, as "pretty bad", means very different things to different people. If it is cosmetic only, and you can live with that, maybe you won't have to fork out more than that screen cost... But... It's possible that it's also got other things wrong with it inside that we can't know about yet. Some of these (possibly damaged) things might be expensive and /or difficult to repair. There are more parts available here, you can add up the numbers of what you can tell you need, ballpark the numbers for the things that might be... But the only way to get a good idea is to get the puppy open and look, there's also the question of whether you can afford either option.... And whether you want to dive into the repair yourself... And whether you can get the repair done by someone else for a reasonable price are all stuff you need to weigh. The model page has guides to help you. Go For It!
If you decide to go for it, and need more help, just take photos of what you want advice on and ask, people will be happy to help you!
Good luck.
Replace a display compatible with a model A2338 MacBook Pro 13" laptop. Includes the 2560 x 1600 pixel IPS panel with True Tone, Display Cover, Bezel, FaceTime HD Camera, Clutch Hinges, Display Daughter Board, Cable Spring Mechanism.图片
产品
MacBook Pro 13" (A2338) Display Assembly
$494.99
这个答案有帮助吗?
得分 1
4条评论:
I should mention that if it works fine with an external monitor, it is a very good sign that all you need is the new screen as far as internal damage... so try that. Sadly it is not possible to replace ONLY the bad parts in the screen assembly... the parts are sold as single modules to ensure that repair is as expensive as possible to 'encourage' you to buy a new one instead... (environmentally conscious of them, yes?) that's the current "repairability" of the company's products. I, for one, detest the practice... but it is what it is.
由完成的 分享
@uchetil - Recovered used display assemblies are cheaper and reduces by one new part need from the factory saving the environment a bit!
As an example MacBook Pro 13" Complete Display, Silver (M1 2020/M2 2022) : Grade-B depending on your MacOS release you might be able to reenable TrueTone! Apple now offers within their newest MacOS a way now to add replacement parts back in!
由完成的 分享
@DanJ,
Good advice, I never actually work on Macs so I'm not up on the current parts availability, Thanks!
由完成的 分享
@uchetil - You took care of the question quite well! Here's a good used parts house in the UK I often use for Mac parts TheBookYard
由完成的 分享
添加一条评论
添加你的答案
Alexa Pavan 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 25
总计 215
