跳转到主内容
加入维修社区 - 创建账户
在2017年6月,Apple更新了13寸的MacBookair,他换上了更新更好的Intel Core i5处理器,让性能和电池续航时间提高。
Why is there a 'Jumper' wire? For what purpose?
Continuing from this question (Solved) Charging issue (Fading Green Light Only)) I have noticed this jumper wire has been installed..... I cannot find any purpose under the schematics that I understand.... ??? Anyone know?
2017 A1466 13" MBA / Board # 820-00165
R6125 / R6120 (Mount type SMD Jumper to Pin > R6110)
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
3条评论
@oldturkey03 It is sometimes charging the battery and sometimes giving the fading green or orange light and not charging.... temperamental.
Zenner Diode D7012 (Voltage Divider) was shot, and is now correctly charging the battery..... but, still getting a fan error in diagnostics & a thunderbolt hardware issue which we are still troubleshooting.
Replacing a burned USB Port
完成的
@livfe sounds like your lines to the SMC are flaky. Don‘t forget to check those. It‘ll be a bit of a chase….nothing worse then intermittent failures. Best of luck and let us know how it works out.
完成的
@oldturkey03 Yeah that will be the last job to do after we fixed (IF possible) the thunderbolt port issue, maybe maybe if that gets fixed it makes a miracle!
完成的
添加一条评论
1个答案
已选择的解决方案
@livfe good question. Looks like your logic board has issues with the EFI IC. That jumper seems to supply SPI_MLB_CS_L which is needed for your logic board to communicate with the EFI. Could be related to your issues with the charging, since any issues with the SPI_MLB_CS_L prevents the system from initiating the basic power-on sequence. That means the SMC is probably not initialized and can't send the signal to the charger IC U7100, to begin the charging process ¯\_(ツ)_/¯
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
livfe 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 24
总计 178
