跳转到主内容
加入维修社区 - 创建账户
惠普台式机维修指南。
How can I tell if the CPU I get is from a Lenovo PC (PSB locked)?
I have the EliteDesk 805 G8 variant of the Elite Mini 805 before HP rebagged it as the Elite Mini, then back to the EliteDesk, but under the EliteDesk 8 G1a or G1i label. The EliteDesk version is functionally the same except for the nameplate, BIOS name, and 2.5" caddy, which the Elite Mini does not have or need unless you run dual NVMes. However, mine has the Ryzen 3 5350GE APU, but the price matched. I want to see about putting a Ryzen 5 5650GE in the machine, being the rest is good (16/512), but the CPU is the weak spot -- okay, it's a quad-core chip which blows away every low-tier chip before Ryzen 3000 with 4000 being similar, but the 5 is a six-core part. The issue is that Lenovo PSB locks their CPUs, so I can't use a Lenovo pulled CPU in my HP :-(. NOBODY MENTIONS THE ISSUE UPFRONT WHEN I LOOK!
I am trying to find a way to check this before I buy the CPU (I know sometimes ratty systems come up with the "right CPU" under the ProDesk series, but usually the CPU is easier to get then a crappy cosmetic ProDesk, or from a parts unit with a persistent BIOS password that can't be cleared being on the SureStart memory vs CMOS RAM), but none if the sellers of bare CPUs mention if it came from a Lenovo - this is compounded by the searches I do for it pulling up the locked Lenovo PCs mixed with the CPU I want, and I know I can't reuse a locked Lenovo CPU to the degree I need to treat the installed CPU as PSB locked because the odds of it being "usable" is extremely low.
Is there some code unique to the AMD OEM CPUs that ONLY shows up on those I can use as a filter, or will I just need to roll the dice and pray it isn't locked, or upgrade a cheap 16/256 unit with the Ryzen 5 to 16/512?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论:
@oldturkey03 have you run into this yet? Best I can tell, it's a dice roll :-(.
完成的
添加一条评论
1个答案
I don't have an answer for you, but I would be curious to know. Because I know Lenovo does this with Ryzen CPUs especially. I don't expect there's anything really special about the CPU's though. This is both a function of the board and the CPU working in tandem since the CPU would need to verify the board and vice versa if this were to work successfully. That would lead me to believe a specific SKU or something is not needed.
My best guess is that you may have to roll the dice. Sadly. Because I can't seen anything that might indicate otherwise so.
这个答案有帮助吗?
得分 0
1条评论:
I'm at a point I genuinely feel buying a "on prem" office or surplus WAH machine with the 16/256 setup with this Ryzen 5 and upgrading the SSD is the better play, or just keeping the R3 I have :-(. I knew this would freaking happen when Lenovo pulled that PSB crap. Complete waste as I just want to put the CPU in my R3 unit, and it angers me that PSB is used on a desktop. it's still a LOT better then 3000 and older R3 chips by a long shot.
Servers? Ehh, the chain benefits and we know. But on a DESKTOP CPU where the machine is basically a thick client with a cheap 256/512 SSD and GPO policies making it like a thin client where it's all on the drive and dies there OR goes to a server with PSB??? I don't agree with it on servers (and I like how HPE uses SureStart over PSB, but Sell and Lenovo use PSB so your initial CPUs being locked is expected), but I can see a smidgen of logic. I was hoping the Lenovo destined CPUs have a "gimme" in the part number :-(...
完成的
添加一条评论
添加你的答案
Nick 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 18
过去 30 天: 57
总计 502
