跳转到主内容
加入维修社区 - 创建账户
任天堂于 2011 年 2 月发布的首款 3DS 掌上设备,型号为 CTR-001。
Original 2011 3ds part called ctr ir 01 came off
I accidentally dropped my 3ds on the floor after moving my arm and a part detached from the motherboard called ctr-ir-01. Does anyone know how to put it back and what it does.
Do I even need this part and do I solder it or something.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
This board is for Infrared signals. It is not necessary and you should not need to solder. It probably just popped out of the connector. There's a little connector on the underside of that board that should pop into the connector in the board you pictured labelled P24
这个答案有帮助吗?
得分 3
1条评论:
Thanks Alisha!
完成的
添加一条评论
添加你的答案
D3CPUH3R0 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 27
总计 129
