跳转到主内容
加入维修社区 - 创建账户
任天堂 3DS 的升级版。它拥有更大的屏幕、更长的电池续航时间、更高的像素密度和更好的设计。
Crack on midframe where the hinge is located (internet led)
my question about the current situation is: what should i do?
  • take it to a repair shop (costs 100€ from what one of the repair shops told me)
  • try to repair it myself (not that experient + shaky hands)
  • buy a case (and what would be best cost/benefit for the situation)
  • leave it as is
pictures:
i dont know for how long the crack has been there. i believe it to be for a while now but i only found out about its dangers this week.
i am a college student, so using up 100€ from savings is a huge toll on me, but im also aware of the 3ds prices so like not that expensive
thank you guys so much for your help!
for context: i have ocd and idk if im focusing too much on the problem or if the anxiety is more than valid
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
as far as im aware the rest of the nintendo has no other crack
完成的
添加一条评论
1个答案
已选择的解决方案
Hi!
I would just leave it like how it is. If it's likely that you will drop it, then buy a case so that it at least won't get worse for now.
This repair is NOT easy, so if you want to repair it, I would go to a local repair shop and ask them.
But as long as everything works and if the 3DS is closing and opening as normal, I would just leave it like this.
Please let us know if you have any questions!
这个答案有帮助吗?
得分 2
6条评论:
@dan0 the only thing ive noticed is that when i open the 3ds the clicking sound is really loud. otherwise, everything else is fine. since i usually only play at home i think its gonna be fine then, but i might just buy a case and look around for a cheaper repair shop. thank you a lot!
完成的
Ah then I would it like that. It’s fine! If it get worse or completely breaks, I would ask a repair shop :)!
完成的
hey @dan0 one last question and thank you so much for your help so far! do you think superglue would work? i wouldnt open it just put a drop of superglue on the visible crack. and also i didnt quite understand what you meant on your last comment haha on the "i would it like that" thank you so much once again!
完成的
Ah sorry, I meant, I would leave it like how it is now!
Hmm, I advise not to put super glue there, just leave it how it is :)! It should be fine!
完成的
thank you a lot!
完成的
显示更多的1条评论
添加一条评论
添加你的答案
Gabriel Silva 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 44
总计 325
