My Lenovo Laptop's charging port doesn't work.
The part above the charging port is broken and loose. It won't charge, so please help me to fix it.
You may have to either resolder the DC-In jack to the motherboard or if the jack is internally faulty, replace it as it cannot be repaired.
Either way the laptop will have to be opened and the motherboard removed from the case. You will need soldering tools and skills to do the repair.
If the DC-In jack is faulty and needs to be replaced, search online for Lenovo IdeaPad 3-15ITL6 DC-In jack to find suppliers that suit you best. (examples only)
Here's the hardware maintenance manual for the laptop.
Go to p.58 (64 of 86 pdf) in the manual, to view the procedure to remove the systemboard so that the DC-In jack can be accessed and worked on.
Here's a video that shows how to remove replace the DC-In jack on the motherboard that may also help.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 12
总计 172
