跳转到主内容
三星公司于2018年3月发布的旗舰手机,盖乐世 S9。
S9 overheating, camera not working
Hello,
I have the following issues in case anyone knows what is the problem:
  1. Front & rear camera are not working
  2. LED notification does not work
  3. Phone overheats when charging (turned off)
  4. Phone overheats more while on, and drains battery very fast
Has not been dropped or disassembled, it all started after I found it with totally empty battery despite it was on the charger.
Appreciate any ideas since I am away from home on business and I don't have access to my tools to disassemble and check source of overheating.
Thank you.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论:
5. Also fingerprint reader is not operational
完成的
添加一条评论
2个答案
@chrisp87714 based on your assessment of "Phone overheats when charging (turned off)" and "Phone overheats more while on, and drains battery very fast", the very first task I would undertake is to replace the battery. Remember heat-short circuit. Could be the battery or even your cameras. Start with the battery. If nothing else it'll be a great known-well starting point for any further troubleshooting.
三星 Galaxy S9 更换电池 Sorry, but it looks like you will have to borrow some tools from somewhere. I don't think this is fixable with a software setting.
这个答案有帮助吗?
得分 0
2条评论:
Hello,
Thank you for the quick response. Yes it's most probably a hardware issue. I mentioned lack of tools because I can't open the cover and troubleshoot further to see if excess heat is coming from the battery or the mainboard. If it's any worth, the phone gets hotter at the top part above the camera and also opposite on the screen, and the sides around the buttons, less on the area of the back cover where the battery is underneath.
I also suspected the battery first but I'm thinking that it wouldn't render the camera and the notification led inoperable. Do you have in mind a case where a failing battery is causing such disruptions and overheating on the board? Or one where the camera was faulty and causing overheating?
Thank you.
完成的
@chrisp87714 this case sounds more like the cameras shortening out the power rail. This could be through on of the cameras PMIC. Hardware wise not much going on above the cameras most of the battery PMIC's are on the opposite side of the battery.....
完成的
添加一条评论
Well looking to your issue i will suggest you to do the following it might help you in fixing the issue:
  • Boot into Safe Mode
  • Boot into Recovery Mode
  • Check charging current
  • Try charging with phone fully off for 15–20 min
  • Remove SIM and SD cards
  • Software refresh
And to fix the over heading issue i will suggest you to check out the following:
https://eu.community.samsung.com/t5/othe...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Chris P 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 40
