跳转到主内容
The Nokia E71x features 3G, Wi-Fi, Bluetooth, GPS, and a 3.2-megapixel camera.
2 个问题 查看全部
How to repair the connector for power adapter (in phone)
The problem with my Nokia E71 is that the power adapter connector in phone doesn't fit exactly (It loose).
Power adapter is tested in multiple Nokia phones and it is working OK.
So I should change the power adapter in phone.
In what part is the adapter?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
2条评论
is it an E71 or E71x
完成的
this will show you how to open your phone Nokia E71x Motherboard Replacement
完成的
添加一条评论
1个答案
已选择的解决方案
If it's an E71 and I assume is same as E71x, then just look on ebay for a replacement power adapter socket. You'll need to find other vids on taking the E71 apart but it's easy to replace the socket. Had same issue on mine but I replaced doing the above.
Issue is getting the casing off and back on without cutting the ribbon cable that is on the right hand side of the phone. I've nicked mine but appears to be just related to the volume. So got a working power socket but now can't turn the volume down :)
Still, was worth it to replace the faulty socket.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Late 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 2,306
