跳转到主内容
加入维修社区 - 创建账户
苹果公司于 2015 年 9 月 25 日发布的 iPhone 6s 维修信息与指南。型号:A1688、A1633
a screw chart for iPhone 6s ,
have taken apart an iPhone 6s kept screws on magnetic board and cat has jumped and scattered them all over bench,
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @janstephenbroom
Not so much a screw chart, but if you don't get a better answer, in the ifixit iPhone 6s repair guide, the screw sizes are mentioned in the various procedures.
For example in the Battery replacement guide in Step.1 it says to "Remove the two 3.4 mm P2 Pentalobe screws on the bottom edge of the iPhone, on either side of the Lightning connector.".
You may need to have Vernier caliper or micrometer though to make sure that you're using the correct screw as some are very close to being the same size but not quite e.g. in the Battery replacement guide at Step.15 there are two screws holding the battery connector bracket. One is 2.9mm and the other is 2.2mm. So you may have to measure the depth of the screw hole as well
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Jan Stephen Broom 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 44
总计 343
