跳转到主内容
加入维修社区 - 创建账户
A2116 / 2019 / 3.6 GHz 四核 i3、3.0 GHz 六核 i5 或 3.2 GHz 六核 i7 处理器。发布日期为 2019 年 3 月 19 日。
Can I swap the logic board from a 2019 21.5" 4k iMac with a 2017 4k?
I have a 2019 21.5" 4k iMac that was damaged in the corner of the screen that both cracked it as well as bent the corner. Replacing the screen is not an option because I wouldn't be able to straighten the corner. The computer still fully runs if not for shattered glass everywhere.
I know there are two versions of the 21.5" iMac that were made in 2017. With one being 4k and the other not. I am only asking about the 4k version.
With the I/O on the back matching both 2017 and 2019 models, if I found a 2017 4k model, could I swap the logic board and even potentially the power supply if that was also needed?
The why is that the 2019 version has the Radeon Pro 560X (I wish it were the Vega 20) and I would want to update the RAM and the blade drive as well while I was in there. I also think I could get a good deal on one that was firmware locked or a failing hard drive that might make it less expensive. I like using old hardware for a long time as well as playing around with upgrades.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
How about just getting a new rear shell iMac 21.5" Retina 4K Rear Housing Unit - Leg Version (19)
这个答案有帮助吗?
得分 0
4条评论:
@danj I feel like getting a new rear, swapping everything over and then buying a new screen would make it more expensive than finding a 2017 model that’s firmware locked.
I use that example because I’ve seen it in previous models being sold cheap, and I wouldn’t feel bad recycling the board. If the board worked I’d try to sell it separately
由完成的
@sparklepimp - You would think Apple would have a common case as well as a display which is carried forward within common generations. I have often been surprised that is not the case. So are there any clues when they are? As it turns out there is! Here we need to dive into the Model ID. Let's look at your two systems
iMac18,2 - 21.5" 2017
iMac19,2 - 21.5" 2019
So here we see the major increment of 18 to 19 so Apple see's these these as different . For reference let's look at these two systems
iMac14,3 - 21.5" Late 2013
iMac14,4 - 21.5" Late 2014
Here we can see the minor digit changed and the parts are interchangeable excluding the logic board.
So just looking at the ID Apple see's the '17 & '19 systems as different.
(Cont)
由完成的
So that doesn't deal with drives or other common interfaced elements like power supplies.
But the case... that's tricky, one has to look at the part numbers to see if they are common (verified as such) so I pointed to above to P/N 923-03079 now let's look at 2017 rear shell P/N 923-01615 TheBookYard crew does a very good job of checking compatibility as you can see in this link both the standard and 4K models share the same shell but if you look at the 2019 link you can see there is not even computability even between the two 4K models. This is a common issue when the boards layout forced the mounting stud to be moved and/or the attached ribbon cable within the shell moved.
OK, let's look at the display and then look at the costs
Here we can see the '17 & '19 share the same display! P/N's 661-12564 & 661-0732 this one is the Grade-A
(Cont)
由完成的
There is a cheaper version Grade-C at $145 US
So if we look at the parts costs
Shell - $115 ~ 203
Display $145 ~ 261
Somewhere around $260 ~ 464 total cost for the parts
So... is it worth the gamble? It still might be possible to use a 2017 shell you may need to modify it cutting away a stud and a ribbon cable may not route correctly and require the sub part be swapped out from your old shell to make things work. Think of the work having to move over sub pieces Vs the major assemblies.
由完成的
添加一条评论
Well both share the same chassis and display panel design, so mechanically the 2019 logic board will fit in the 2017 enclosure.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Michael 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 25
总计 391
