跳转到主内容
加入维修社区 - 创建账户
索尼 PlayStation 5 DualSense 手柄(第一代)的维修指南、拆解信息和故障排除信息,它是 DualShock 系列的继任者。可通过产品型号 CFI-ZCT1W 和主板型号 BDM-010 进行识别。
DualSense flashing three white lights when turned on.
Hi there, apologies if this has been answered; I couldn't find it anywhere. I opened up my DualSense and replaced the battery. Now when I turn it on, it flashes blue and connects as normal. The controller works perfectly as well.
The only difference is that now, instead of flashing one white light, it flashes three. I couldn't find anything that explains what this means. I was planning on opening up the device again and checking the connections, but before I do, does anyone happen to know what it means?
EDIT: Here is a video of the issue, hopefully it will play. With the PS5 off and disconnected, I hit the PS button on both controllers. The black controller flashes the blue light bar and one white light. The white controller flashes the blue light bar and three white lights.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
4个答案
最有帮助的答案
Hi!
First of all, make sure that everything is connected as how it should be! Maybe something isn’t connected properly (or fully connected).
You can also try to reset the controller and see if that fix anything.
Is the controller up to date? What happens if you use it directly?
Thanks!
这个答案有帮助吗?
得分 1
9条评论:
Hello and thank you for your help! I don't see any loose connections in the controller, and I disconnected and reconnected the battery and mic, no change.
Resetting the controller unfortunately also produces no change (I've done that one several times, haha).
The controller is up to date, and plays games perfectly. The lights are normal once it connects, whether by Bluetooth or by USB.
The issue only happens while it's connecting. Instead of one white LED flashing, it flashes three.
Would any pictures or video in particular help to diagnose?
完成的
Thanks for the testing! You can upload a video so we can check. The error is not common. Usually it's blinking orange and fail to connect. So it's weird what is happening here....
完成的
Got the same issue, any news about this problem? After some time playing it even messed up my other controllers, then I had to restart my PS went to options forget all DS’s and then via USB connected all again. Checked all connections seems all good inside this one DS. But yeah same issue still exists.
完成的
Did you opened it up before? It's most likely motherboard related in your case.
完成的
I’ve edited the question to add a video of the problem. The controller works perfectly fine, this is just a strange oddity.
完成的
显示更多的4条评论
添加一条评论
Well I will suggest you to checkout the following video: https://www.youtube.com/watch?v=zRtsUg4X...
这个答案有帮助吗?
得分 0
1条评论:
Hi there! Thank you for the suggestion. Unfortunately it did not resolve the issue.
完成的
添加一条评论
I have exact same issues mine flashes four times, Controller working fine and it Dualsense version 5. any update on this ?
这个答案有帮助吗?
得分 0
1条评论:
Hi!
Please check the comments from my answer. Thank you!
完成的
添加一条评论
Nah masalanya stik ps5 saya lampunya ga mau idup, tapih klo dices idup lampu kuningnya
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
AkiraRagnas 将永远感激不已
浏览统计数据:
过去 24 小时: 9
过去 7 天: 61
过去 30 天: 313
总计 2,600
