跳转到主内容
加入维修社区 - 创建账户
广受欢迎的 Apple 迷你桌面电脑,2024款 Mac mini 的维修指南,拆解信息和疑难解答。该机型使用 M4 或 M4 Pro 处理器,最低配有 16GB 统一内存。
Mac Mini - no hdmi and blinking red
I usually switch my monitor between my Mac and PC. One night, my Mac mini’s screen wouldn’t turn on—I thought it was just asleep, but it wasn’t.
I thought the storage becomes faulty since I upgrade it but I tried using the original storage but I got the same result.
Here’s my situation: after plugging in the power, the Mac mini’s light keeps glowing on and off. When I press the power button, there’s no chime or response—just the same pulsing light. The dock station connected to my Mac mini isn’t turning on—there’s no light on my mouse.
Here’s the thing I have tried.
  1. I hold the power button to turn it off. Then I press it after again. I can hear the chime and there’s white light glowing for a while after a several mins the light will turn to blinking red.
  2. I have successfully “revive” the original storage but still the same result.
  1. Also I just found out that the dock station slot I use to connect my Mac has a blinking light, which means it’s having trouble maintaining proper conductivity. The other slot works fine. Also only the mouse is connected to the dock station so believe I'm not overloading on it too.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
5条评论:
To be clear the front normally White LED is now blinking Red?
完成的
its white glowing for a while after a several mins the light will turn to blinking red
完成的
@macuserzat172 - the system will need a DFU reset. Best to let Apple do this that's assuming the original NAND still fails the same which I think it will.
完成的
Is that wherein you have option to restore or revive the mac? yeah I have succesfully revive the original NAND but still the same. I'm trying to restore both of the NAND but im having some issue.
完成的
@macuserzat172 - time for that visit to the mount of Apple for there skilled workers to fix your system under warranty! But the clock is ticking, don't loose the window as if they are unwilling it will be costly!
完成的
添加一条评论
1个答案
Your system should still be under warranty, I would get to an Apple Store or authorized reseller to get it looked at. This doesn't sound good!
这个答案有帮助吗?
得分 0
6条评论:
wait I thought I already void my warranty after opening the unit since I upgrade my storage.
完成的
@macuserzat172 - slide in the original Flash I won't tell 😁
完成的
Apple nabízí bezplatnou opravu, ale jen pro určité s/n
Apple offers free repair, but only for certain s/n
完成的
@vladimirneuman - Není to definováno sériovým číslem systému, ale stářím systému, dva roky od data zakoupení, a Apple vám v tomto ohledu také dá trochu prostoru pro manévrování!
It's not defined by the systems serial number it's the age of the system, two years from date of purchase, and Apple will give you a bit of wiggle room as well on that!
完成的
Our seller provides a one-year warranty, so I was excluded from the repair.
完成的
显示更多的1条评论
添加一条评论
添加你的答案
macuserzat172 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 39
总计 377
