跳转到主内容
A1418/EMC3069/2017/3.0GHz四核心Intel Core i5、3.4GHz四核心Intel Core i5或3.6GHz四核心Intel Core i7处理器。于2017年6月8日发布。
Every task running slow
My Imac has been running extremely slow on all tasks, booting up, browsing the web, openinig a folder or file, launching an app.. ect.
Even after ive removed a lot of redundant files, cleaned and scanned the drive for malware, nothing seems to fix it
Sometimes If its being used for a period of time its slow but not too bad. its almost like its warmed up.
But if left for a while and you come to use it it takes a while to get going. sometime you might be waiting over a minute or two just to open a file
Anybody experienced the same thing? Any ideas? Could the hard drive need replacing?
Thanks in advance
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Is your system a Fusion Drive?
Have you run the system Diagnostics? Restart the system and press the D key to enter Use Apple Diagnostics to test your Mac yet us know what it reported.
这个答案有帮助吗?
得分 0
4条评论:
thanks for the reply
I no idea how to check its a fusion drive system.
Ran Diagnostics and all seems to be OK
I do have a couple of screen shots but it look s like im unable to upload in here
No issues found
Reference code : ADP000
Then it goes on about support.
I also ran first aid on the volume
That operation was successful.
The drive itself is a 1TB with 913gb available.
Is there anything else you can suggest I try?
Thanks
完成的
@wayne16803 - I'm leaning on a failed SSD drive. A Fusion Drive is two physical drives a SATA HDD and a second hidden SSD drive which is used as a Cache drive to the HDD. To prove this is the fault you'll need to have an external drive which your system uses as its boot up drive. Here's the hidden SSD iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement.
Do you have a drive you can setup as a bootable external drive?
完成的
@danj
Sorry for the long delay in replying. Ive set up a pen drive to boot from.
Im assuming its just a case of running first aid on the internal drive?
OK ran it on all drives that appeared under internal and all passed apart from the parent (drive at the very top)
'problems where found with the partition map which might prevent booting
counld't mount disk. :(-69842)'
What does this mean and is there anything else I need to run or check?
完成的
@wayne16803 - Well that's not good! The SSD is having problems. You should backup your stuff ASAP as you need to reformat the drive. Hopefully that fixes things.
完成的
添加一条评论
添加你的答案
Wayne 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 45
