跳转到主内容
修复你的物品
维修的权力
配件 & 工具
Model A1285 / 8 or 16 GB capacity
246 个问题 查看全部
LCD is dark - plug in charger lights up for split second
Got a Nanon 4th generation, 8GB. The LCD is totally dim, did a factory reset ... weird thing is if I plug in the charging cable in from time to time it lights up fully for a split second then goes dim. But not all the time.
Guessed it might be just a loose lcd cable, but jiggled, tapped, etc, with no results or flicker.
Figure I will just order in a new lcd, but just wondering if someone has experienced the same issue (just kinda voodoo weird) out of curiosity.
已回答! View the answer 我也有这个问题
这是一个好问题吗?
得分 2
评论:
btw, tried different charging cables, same result, wanted to note that.
完成的
添加一条评论
任天堂 Switch 套装
A quick fix to get back in the game
Shop Switch Kits
任天堂 Switch 套装
Shop Switch Kits
1个回答
已选择的解决方案
Country Computer Service, this model iPod has issues with corrosion on the logic board especially around the display connector. I would start by cleaning the logic board thouroughly and replacing the LCD.
这个答案有帮助吗?
得分 3
评论:
Thanks, I'll do that.
完成的
添加一条评论
添加你的答案
Country Computer Service 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 1
总计 588
