battery cell replaced but still not working
I have replaced all 5 cells on my Parkside drill v18 battery and the total reading is the same as a working battery. but it is still not working there is no reading on the light indicator like it so dead.
one of the thing ive noticed is the different in the no-working battery having - to the + on 0 but to the - to the c has full volts where the working one have all volts to both the + and c terminal
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
@alexandersaxby what cells did you use and did you double check your work? Made sure that all cells are properly connected etc.?
完成的
im not sure on the calls name but the size and total voltage is the same as a working battery
and yes i have check my work the voltage on the batt+ to batt- is 20
完成的
添加一条评论
