跳转到主内容
Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1203 个问题 查看全部
Remove space bar to clean under it
Hi,
my space bar is over reactive. It writes a " " when I lay my finger on it. Quite hard to write longer texts with it. I'm expecting dirt under it, do you think so too?
How to remove the space bar without destroying it? Thanks for your help.
Greetings
Chris
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
3个答案
已选择的解决方案
Get the tips of your pointer fingers slightly under the top edge of the key, press down on the bottom of the key with your thumbs, and with a firm and somewhat forceful motion, pull the key back very quickly from the top. It's like removing a bandaid -- do it quickly. If you do it slowly, you run a higher risk of damaging the internal components.
Most of the spacebars have a couple metal bars running the length of the key. Their ends need to be secured in tiny holes at the base of the spacebar area, however the metal bar, especially the top one, often comes loose when pulling the key back. Make sure the ends are properly seated in the holes, and make sure the upper bar is flipped upward so that it runs against the top of the spacebar area (if it is in the downward position, it will not fit into the notches on the underside of the spacebar). The bottom half of the spacebar can remain connected while it is pulled back from the top. As for working inside the key, I prefer using tweezers, because other instruments tend to be too blunt.
Once everything looks good, position the spacebar back in place, and press it firmly downward with several fingers. Press your finger across the entire length of the key in order to make sure all of the clips have secured themselves.
Please note, there is always a risk of breaking some of the small plastic clips when removing a key. no matter how good you get at it, you will probably break a key every now and then. Although, like I said, pulling it back very quickly helps reduce the potential for damage.
这个答案有帮助吗?
得分 4
添加一条评论
You use a toothpick to pop off http://www.youtube.com/watch?v=E--mfTViQ...
这个答案有帮助吗?
得分 1
1条评论:
I'm afraid the spacebar is an entirely different animal....
完成的
添加一条评论
http://www.youtube.com/watch?v=IIpgG9fHc...
might be similar to this.
kind regards,
Rens
这个答案有帮助吗?
得分 0
1条评论:
It's relevant, but he's making it a bigger deal than it needs to be -- you don't have to completely remove the spacebar. If you just fold it back and leave the bottom connected, you get the same result in less time, and there's less risk of damage.
完成的
添加一条评论
添加你的答案
Chris 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 2,685
