跳转到主内容
型号 A1238 / 80, 120, 或 160 GB 硬盘 / 黑色或银色面板
896 个问题 查看全部
Is there a way to distinguish "thick" and "thin" by model #?
Looking for a way to identify the "thick" 160GB Classic by model number or serial number, without measuring.
Trying to buy "thick" Classics on-line, without having to have seller measure iPod.
I think the difference is only about 0.1"
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
2条评论
thanks for the help.
完成的
They no longer offer this option for iPod classics - this doesn't work. The tech I spoke to thought I was crazy thinking there were 12 different models.
完成的
添加一条评论
3个答案
已选择的解决方案
Unfortunately, there is no distinction in model number between the thick and thin 160 GB Classics.
The best way I have found to distinguish them without opening it up is to do the following:
  1. Locate the serial etched on the rear panel of the iPod.
  2. Go to Apple's Online Service Assistant and enter your serial number and country.
  3. Look at the text under the picture on the left. If it reads "iPod Classic," you have the thick version. If it reads "iPod Classic (Late 2009)," you have the thin version.
Good luck!
这个答案有帮助吗?
得分 12
4条评论:
Thank you for your answer. i have a thin ipod.
完成的
Brilliant, thank you for this :)
Also just to add to above, if you look on back of Ipod and it says Model: A1238, then it is a thin, 2009 version (aka 7th generation). On older models the last three characters of the serial number will be one of these: Y5N, YMU, YMV, or YMX.
Ben's link above no longer works but see here:
https://support.apple.com/en-gb/HT204217
完成的
Ignore the comment saying A1238 is the thin model. A1238 applies to the 5th Gen (2005) through the 7th Gen (2009). As it states above, the model number doesn't show if it's thick or thin. Check the serial number on Apple's support page.
完成的
Use https://checkcoverage.apple.com/ to check serial numbers with Apple
完成的
添加一条评论
I found one is slightly heavier 5.7ounce~163g for thick 4.9 ounce ~137g for thin
so iweighed mine with a digital kitchen scale to find out
also see below link
http://www.everymac.com/systems/apple/ip...
thanks..
这个答案有帮助吗?
得分 5
2条评论:
Thank you for your answer. I have weighed my and it is a thin ipod.
完成的
Mines 160g so close enough to call it the thick one. Thanks.
完成的
添加一条评论
take a look at everyiPod.com
The distinct model numbers are listed there for the original (thick) and Late 2008 (thin) models of the Classic 160GB (there are also different model numbers for silver and black variants)
you can also try the model lookup page on the same site.
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
mahonken 将永远感激不已
浏览统计数据:
过去 24 小时: 11
过去 7 天: 102
过去 30 天: 417
总计 46,734
