跳转到主内容
加入维修社区 - 创建账户
1975-2011 (The picture is of a 2008 grand marquis)
Milky dipstick how to fix
I can’t tell what is causing the oil n coolant to mix i doing see no smoke from tail pipes
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
@rickyperales what is the exact year and engine size for your Mercury?
完成的
添加一条评论
1个答案
最有帮助的答案
You may have a leak in your oil cooler. The tailpipe white smoke is usually from a blown head gasket. You should check your coolant to see if there is any oil in it, and to check the coolant level. Change your oil right away, too.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Ricky Perales 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 23
总计 146
