跳转到主内容
加入维修社区 - 创建账户
Touch stops responding and only responds to long press
When I use my phone it stops to respond to my touch and only work if off and on . And I have to constantly touch my phone to make it respond to one command like touch 2 second and swipe without removing finger out of display 😭 it's annoying
回答此问题 我也有这个问题
这是一个好问题吗?
得分 5
3条评论:
The most common causes of this are software glitches, screen calibration issues, and hardware failures. The device should be restarted, software should be updated, screen protectors should be removed, or the touchscreen should be checked professionally.
完成的
Same, I have the same problem and I think it's because of the screen protector.
完成的
My phone doesn't have any cracks or scratches on its screen, but when I play games, the enemy actually stops touching me. If I turn off the screen for a while and do it again, it's fine. Sometimes it happens on Messenger.
完成的
添加一条评论
2个答案
First thing is to try booting into Safe Mode. This will disable any apps that could be interfering with the touch screen. Power off the phone, then follow the instructions from the Xiaomi help page.
Safe Mode FAQ
1. Q: How to turn on safe mode on the phone?
A: When the phone is turned on, long press the volume down key to enter the safe mode. After entering the safe mode, the word "safe mode" will appear in the lower left corner of the phone screen.
If that works, the problem is with one of your apps. You'll need to delete any apps you've installed, one at a time until you find the one that's causing the problem.
If the issue is still there in Safe Mode, it's likely your digitizer (touch screen) has failed and you'll have to replace the screen to fix the problem. Here's a guide giving you instructions on how to do that.
Xiaomi redmi 12c screen replacement and disassembly using original display - YouTube
这个答案有帮助吗?
得分 0
3条评论:
I just did the factory reset but still not fixed so might that be my hardware problem??
完成的
@rohitkhana77699 By far the most likely cause at this point is a failed digitizer, so a screen replacement is what I would do if it was my phone.
完成的
Ekranda sorun yok. Herşeyi denedim fabrika ayarlarına çevirdim degilmedi
完成的
添加一条评论
But my display not cracked
这个答案有帮助吗?
得分 0
1条评论:
There are several ways a touch screen can fail, so the glass being undamaged doesn't mean the digitizer is still working.
完成的
添加一条评论
添加你的答案
Rohit Khanal 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 26
过去 30 天: 104
总计 443
