跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2193 个问题 查看全部
What Part Do I Change Once The iPhone 4s Gets Wet?
My phone decided to take a swim! yeah I know right? I've been letting it sit in rice for more than 24 hours it still hasn't turned back on, incase it doesn't after another 24 Hrs what can i replace to get it going again?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
4个答案
已选择的解决方案
Here is a link to the cell phone water damage guide. Its for 3G but most of the procedures should be the same. Good luck.
修复iPhone 的进水故障
这个答案有帮助吗?
得分 5
1条评论:
Cool I ordered the battery and tools to open it. Gonna see what damage was done. hopefully the rice got most of the moisture.
完成的
添加一条评论
Well, you should never, ever try to turn on a water damaged device.
Water itself is not damaging, but it deroutes electricity where it's not supposed to do.
So, at first, you should dismantle your device and clean it throughly with isopropylic alchol. Let the parts dry, then reassemble and evaluate.
You're surely going to need a new battery: yours surely was shorted when it got wet.
After the battery change, you could check for other signs of damage.
iPhone 4S Battery图片
产品
iPhone 4S Battery
$16.99
这个答案有帮助吗?
得分 4
2条评论:
Thanks I'm gonna give it a shot!
完成的
Be careful. Keep every small piece handy. You may need the "iPhone Liberation Kit" to remove the pentalobes in the back.
完成的
添加一条评论
The most common problem on the iphone 4S which has been exposed to water is battery failure. With the 3GS it is usually the LCD. Remember that the rice trick is only a temporary solution since moisture can still be trapped inside of the main board shielding. Read more about what to do with a wet cell phone here. As a previous poster said, turning the phone on is a bad idea as it causes electricity to flow through components that are still wet. This can easily short something out and cause more damage. Once you replace the battery pay attention to whether the phone gets hot while charging. This is a good sign that you will have problems in the future.
这个答案有帮助吗?
得分 0
添加一条评论
I replaced the battery and it power on and worked for one day then it wouldnt work again the next day is there anything more i can do
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
lab308joe 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 13,433
