My car is not recognizing the key. Is my only key
The chip on my key is not working. Can I reprogram the key myself. It rotates but it doesn't turn on. Thanks.
Mi auto no esta reconociendo la llave.Es la unica llave q tengo.La puedo reprogramar sin tener q llamar un locksmith? Gracias
Update (09/14/25)
2005 grand marquis
3条评论
Hi @alex99751
No it won't start as the control module needs information from the key to know that it is the correct one and not just another key that fits the ignition.
You could try reprogramming the key to see if that works.
If not, it may be problem with the key sensor module in the car.
Search online for "Mercury Grand Marquis (insert year model) how to program fob key".
由 jayeff 完成的
@jayeff can i reprogram it myself? I don't have $ to call a locksmith. Thanks
由 Alex 完成的
@alex99751 It's hard to say; some cars you can and others require specialized equipment. Without knowing the year of yours, we can't look it up for you.
由 Jerry Wheeler 完成的
