My iPod Touch volume/power cable broke.
Now my iPod touch won't show anything. I know it's on because when I hold the home button the voice assistant talks. I did see a white screen once. Also my computer detects it. I can't do any reset because my flex cable for the volume/power is ripped. But i'm also not sure a hard reset would work. Did this happen to anyone similar? Did you fix it? How?
已回答! View the answer 我也有这个问题
这是一个好问题吗?
按维修分数 0
添加一条评论
所有超过US$100.00或包含 Pro Tech工具包的订单免费送货!
浏览我们的商店
Ever fixed something? That’s Genius.
Share your repair story with #ImAGenius
We Are All Geniuses
3个回答
已选择的解决方案
Hate to say this, Justin, but when you replaced the lcd and pulled up the logic board you probably ripped the power/volume flex cable. To repair your iPod, is going to involve desoldering the hot terminal off the battery, pulling the logic board, and soldering in a new flex cable. And if you don't have the right equipment and experience you'll dig yourself deeper into a hole that can include lifting solder pads, solder splash, tearing other cables etc. At this point I suggest you send your iPod off to a business that specializes in iPod repairs.
这个答案有帮助吗?
按维修分数 1
添加一条评论
It sounds like the front panel display went out. I would try replacing it.
这个答案有帮助吗?
按维修分数 0
添加一条评论
I'm having exactly the same problem. How did you fix it?
这个答案有帮助吗?
按维修分数 0
添加一条评论
添加你的答案
Justin Narvaez 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 1,068
