跳转到主内容
加入维修社区 - 创建账户
This is the second-generation Volvo S60. A wide range of powertrains, including the robust T6 inline-six and the later Drive-E four-cylinder engines, were offered.
How do I pop the hood if the interior release is not working?
I went to pop the hood one day and the interior release no longer released the hood. Now how can I get it to rease? I need an oil change soon and to replace a headlight but the hood won't open.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
@beaver94281 seems to be a common issue with Volvo. Anyhow, check this page to follow with those things. Not easy nor straight forward, but it can be done.
Of course, you can also take a pair of Vise Grip pliers and pull on the cable (where it latches into your hood release lever) while someone else pushes a few times on the hood. The pliers may allow you to pull the release cable a bit more than the factory lever does. That may free the hood release.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Beaver 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 19
总计 166
