Adamo 13 - Power cable OR power jack problem?
I will try to be articulate, but may be overtly verbose in trying to explain the issue:
I am having trouble with charging my adamo - I suspect it is the power jack itself.
When I plug the power cable into the power jack, it does not always charge or make a connection. I can see from the battery icon when it has connected.
When I plug it in and the icon for the battery does not activate the battery icon with a plug next to it, I can often manipulate it to charge by applying pressure to the outer base of the power cord while it is plugged in. Unplugging and re-plugging don't seem to make a difference.
What do you think the issue is -- and can I fix it?
Thank you for your time!
1条评论
cate, I've got exactly the same problem. Very keen to hear how it goes.... Also, where did you get your replacement part from? I can't find any online.
由 bob12321 完成的
