跳转到主内容
于2019年11月发售的MacBook Pro 16''的维修指南和拆解信息。型号A2141,EMC 3347。
Why is my computer randomly shuts down with a new battery?
Update (08/27/25)
This might be the reason. The design capacity should be 8700 mAh.
Update (08/27/25)
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
@ramzenzaren - Yes the capacity is not correct!
But I don't think that explains the random shutdown. Can you take one more snapshot this time after clicking on the Battery Info button so the battery info is seen.
完成的
Another thing that I failed to mention is that when it restarts it shuts down once I log in.
完成的
添加一条评论
3个答案
Could be overheating, loose connection, or even a power supply issue. I’d check temps and make sure everything’s seated properly. Sometimes it’s not the battery at all
这个答案有帮助吗?
得分 0
添加一条评论
@ramzenzaren - If the system is able to run a few minutes I would install this gem of an App CoconutBattery it will allow you to see more clearly the health of your systems battery. Take a snapshot of the Apps main window and post it here so we can see it as well.
A helpful tool is a USB-C power meter which you can place inline with your charger to monitor its power delivery.
Here's the guide to replace the battery 2019年16寸MacBook Pro 电池更换
这个答案有帮助吗?
得分 0
添加一条评论
Possible Reasons for this-
  1. Overheating
    – Dust buildup, bad cooling fan, or dried thermal paste can cause sudden shutdowns.
    – The system powers off to protect hardware.
  2. Faulty Power Supply (PSU) or Charger
    – Even with a good battery, if the PSU/charger gives unstable power, the system can crash.
  3. RAM or Hardware Issues
    – Loose RAM, a failing hard drive/SSD, or a faulty GPU can trigger random shutdowns.
  4. Motherboard or Power Circuit Problem
    – Damaged power ICs or shorted components may cause unexpected power loss.
  5. Driver/BIOS/Software Issues
    – Corrupted drivers, outdated BIOS, or OS errors can cause shutdown loops.
这个答案有帮助吗?
得分 -1
1条评论:
@rashmikand95190 - Please review the system details before dropping a generic AI? Generated solution. If this was a desktop then this would have been reasonable. As this is a laptop if fails to even deal with the issues it would likely have and a Mac laptop is different enough to a Windows system, in this case doesn't even have a BIOS chip or built-in power supply.
完成的
添加一条评论
添加你的答案
RamZenZaren 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 13
总计 102
