跳转到主内容
加入维修社区 - 创建账户
iPad Pro 11 英寸 (第 2 代) 发布于2020年3月,型号包括A2228、A2068、A2230和A2231。
After replacing the battery, screen has become partially discolored.
As the title, after I replace the battery (and usb-c-port), screen get partially discolored. I didn't change any parts than these above two.
(right upper part when horizontalized).
Is there a easy way to fix this? If not (how to buy new lcd or display), I give up ...
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
3条评论
I used IPA to cleanse frame and behind display. Is there a possibility that made signinficant part ruin?
由完成的
I don’t know the reason, the discolor disappeared in a few days.
由完成的
@tpzvrxeb1qqmq5l Almost certainly some alcohol got under the display and eventually evaporated. Your screen should be fine now.
由完成的
添加一条评论
2个答案
最有帮助的答案
It definitely looks like liquid contamination on the screen. The good news about IPA (at least at higher concentrations, like 90% or higher) is that it doesn't leave behind residue, so with luck it should eventually evaporate out of the screen. I'd give it a few days, keeping an eye on it to see if it looks like it's getting smaller. You may be able to hasten that by heating it with a hair dryer; blow on it for three minutes or so, let it cool and repeat a few times.
If you've given it plenty of time and it doesn't improve then it may indeed be damaged, in which case you'll have to decide whether you can live with it as is or go to the trouble and expense of replacing the screen.
这个答案有帮助吗?
得分 2
添加一条评论
Hey,
I'm personally not sure if there is a way to fix it as I dont have experience with ipads personally. However if you do end up needing/wanting to replace the screen. I have found links that may help you. Hopefully someone else can assist you better with this issue.
Good luck,
Here is a link for a repair guide.
第二代11寸 iPad Pro 更换屏幕
I also have a link for a screen however as I live in Australia it is an Australian online store.
https://www.polartech.com.au/products/af...
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
S K 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 14
总计 203
