跳转到主内容
加入维修社区 - 创建账户
Xbox Series S是微软于2020年11月10日发布的轻巧纯数字游戏主机,与Series X属于同世代产品。本页面包含 Xbox Series S的维修指南、拆解信息,以及疑难解答。
xbox not turn on but power supply is working
my xbox series s not turn on but when we connect cable to my remote then i know power sypply is working what that problem
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
1. Check the Power Supply (for Xbox One with external brick)
  • Make sure the light on the power brick is solid white or orange.
    • No light? → The power supply is dead → replace it.
    • Blinking light? → Fault in the power supply → unplug for 10 minutes, then try again.
2. Power Reset
  • Xbox One / Series X|S:
    1. Unplug the power cord from the console.
    2. Wait at least 10 seconds (better 30–60 seconds).
    3. Plug it back in and press the power button.
  • If still nothing, try plugging directly into a different wall socket (no surge protector).
3. Check HDMI & Display
Sometimes the console is on but no display:
  • Make sure the HDMI is connected to the HDMI OUT port, not HDMI IN.
  • Test with another cable and TV.
  • Try holding the power button for 10 seconds until it fully shuts down, then power it back on.
4. Eject Button Power-On Trick (Xbox One Only)
  • Press and hold the eject button + power button together until you hear a beep.
    • If it turns on, the power button might be faulty.
5. Overheating / Dust Issues
  • If the console overheated, it may refuse to power on until cooled.
  • Clean vents and make sure it’s in a well-ventilated area.
6. Internal Hardware Issues
If none of the above works:
  • Possible issues: bad power button, motherboard, or internal PSU (on Xbox One S/X and Series X|S).
  • At this point, you may need repair or replacement from Microsoft or a local console repair shop.
Update (08/22/25)
2. Power Reset
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
ujjwal badoni 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 12
过去 30 天: 55
总计 563
