跳转到主内容
2016年9月16日发售。型号有A1661,A1784和A1785,支持GSM 和 CDMA 格式,存储容量有32GB、128GB以及256GB,颜色有玫瑰金、金色、银色、黑色、新的亮黑和红色。
modify iPhone 7 plus battery
hello im just wondering if there is anyone did what im going to do so please help me with this im planning to make modified iphone 7 plus battery i have spare android 5000mah here can i use it to iphone 7 plus do i need a program to program the battery to be read to iphone 7 plus as 5000mah what wire i need to connect iphone 7 plus flex to android battery do i just need to solder it directly or i need red and black wire as extender will my iphone 7 plus read the battery as 5000mah or it will read it as 2900mah
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
I'm fairly confident you're not going to be able to use any BMS, or Battery Management System in an iPhone 7 unless it comes from an iPhone 7. That means you'll have to clip the terminal strips from the little circuit board that's mounted on the battery and attach them directly to the plus and minus terminals of the cell you want to use - after removing the BMS from it as well. If you do use the original BMS, you might want to use a device programmer like the Qian Li iCopy or the JC VS1E to clear the cycle count and health percentage; otherwise it will still read whatever numbers were there when you took it off the old cell.
It's hard to say if the difference in mAh values will affect anything or not. The phone uses voltage and temperature readings to determine the charging rate and decide when to stop charging, so that should all work correctly, but I doubt anyone knows for sure if your battery charge percentage and/or battery health percentage will be reported correctly. There are plenty of sites that claim to sell high mAh batteries, but it's who knows if they've modified their BMS to compensate for the difference or not; they certainly don't include any warnings that your percentages might not read correctly.
While you can solder the terminal strips, spot welding is by far the preferred method. Heat is the mortal enemy of Li-Ion batteries and the spot welder transmits far less heat to the cell than soldering does. If you do solder them, you might consider clamping a pair of hemostats between the cell and the part you're soldering to act as heat sinks to help keep the heat from getting to the cell. Of course you'll want to work as quickly as possible and use the least amount of solder you can so it doesn't hold the heat there in the molten metal.
Sorry I don't have a definitive answer for you, John, but that's about all the information I can give you to help out. How are you planning on attaching the modified battery to the phone, since it obviously won't fit in the same space as the original.
Good luck with your little project, and be sure to come back and let us know how it all turns out. Tell us if the charge and health percentages seem to work after you swap out the cell; we'll be interested in what you find.
这个答案有帮助吗?
得分 1
1条评论:
hello i know about the bms yes i strips it what i mean is JST connector cuz iphone lightning charge is s*ck it will take too long to charge my 10000mah im wondering what kind of charging module do you recommend to charge it up using type c (typce c socket-module-negative and possitive wire with jst pin connector and for the battery it also have the jst pin connector so i could charge it externally and then for the bms its connector to a wire with jst too i mean i could make 2 battery 10000mah so i easily can swap 2 battery if its lowbat via JST pin connector i hope you can help me what wire and module do you recommend
完成的
添加一条评论
添加你的答案
John Martinez 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 9
总计 50
