跳转到主内容
第五代 iPad Air 于 2022 年 3 月 8 日发布。它配备了 M1 芯片和 5G 网络连接。
Slow charging battery after replacement
I recently changed the battery on my iPad 5th Gen. (A2588). I ordered the replacement Part from ifixit (Model A2288 Battery for iPad). The battery works but it doesn't fast charge. It tops out at 12 W instead of 27 W that i see with the old battery.
The ifixit battery number is A2288, the Original battery has the number A2742.
Is there a trick or a software lock?
Replace a 7606 mAh model A2288 battery compatible with iPad Air 4, iPad Air 5, iPad Air 6 11" and iPad 10.图片
产品
$59.99
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Your iPad 5th gen uses battery A1484. The one you got (A2288) is not the right part, so the charging controller limits it to ~12 W. There’s no software lock — just a hardware mismatch. Contact iFixit and ask for the correct battery (A1484).
这个答案有帮助吗?
得分 0
1条评论:
I think you missunderstood something. I have a iPad Air 5 Generation (A2588) not a iPad 5. But i Think you're correct with the missmatched hadware. It's just odd that the replacement battery is advertised as compatible with the iPad Air 5.
完成的
添加一条评论
添加你的答案
gartenzaun 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 9
总计 46
