跳转到主内容
加入维修社区 - 创建账户
Repair guides and support for Nespresso Inissia coffee machines.
Machine not piercing the capsule—water leaks out the back
Hello, After placing the coffee capsule and firmly closing the capsule compartment (capsule holder), I activate the machine. The water is pumped, but it escapes behind the capsule into the used capsule container (capsule bin). I open the compartment and see that the capsule has not been pierced—neither from the front nor the back. What could be the cause of this issue?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
The capsule should already become pierced by the three needle from the back in the moment you fully close the lid/leve, i.e. before activating the machine and pumping water.
If that is not the case, then those three "needle" in the back of the brewing chamber may be worn out.
Which capsules are you using?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Patt Z. 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 11
过去 30 天: 23
总计 105
