playstation 1 with no audio and video
hello, i have a playstation 1 fat, the model is SCPH-7501, when i turn it on there is a slight interference in the tv for a second but there is no audio and video, it has a working power supply, the AV cables are good since i tested them with another 2 consoles and they work fine and the tv also works fine with my other 2 playstation 1's, can someone help me find the issue?
7条评论
Hi!
Could be many things...
How is the AV port? Still looking good? Can also be the CPU or a short on the board.
Do you have any soldering experience?
由 koppie007 完成的
@dan0 the multi out AV port has rust on the top but the pins look fine, and i have a little bit of experience with soldering
由 tailsthefox2014 完成的
Alright, should not be a issue. Can you share some pictures with us? Regarding the AV port but also regarding the motherboard? My feelings are telling that it's the motherboard... CPU or something...
由 koppie007 完成的
here are some pictures of the multi out av port and the mother board[image|3728066][image|3728064][image|3728065][image|3728062][image|3728063]
Hi!
I cannot see the images unfortunately. Is it possible to check this guide?
在已经存在的问题里加入图片
Thanks!
由 koppie007 完成的
显示更多的2条评论
